Tonar8352
I received this beautiful Koa Telecaster from our forum friend buckallred to finish in clear lacquer. Here are the steps and products I used to get it ready for the final finish coats.
The first four pictures show before and after profiles of the body. It came to me ruff cut so I rounded up the edges and made the belly cut deeper starting with 80 grit paper then I went to 220 and finally 320. These pictures also give a good idea of how much the finishing process enhances the beauty of the Koa when you compare them to the final pictures.
After it was finish sanded I shot it with one wash coat of McFadden’s water white lacquer. Next I had to deal with the knot in the back. I used Bondo wood filler that I tinted with color in oil that I got from Dunn-Edwards Paints. I use raw umber and a tiny bit of iron oxide to make the color. Next I filled the wood with clear oil based paste wood filler made by McFadden’s. These two pictures show it filled and ready for clear coats.
Finally here it is with the first coat of clear finish on it. Notice how much the grain is enhanced. The back is more showy than the front but this will be a beautiful guitar once its gets all finished.
