TonyFlyingSquirrel said:Dan0 said:TonyFlyingSquirrel said:Dan0 said:this might better represent how it goes together.
I apologize, but I'm not well versed on how to read those type of schematics. I'm used to reading the ones from Seymour Duncan and Dimarzio.
don't apologize. i'm not sure if i'm trying to be too precise. i hope i'm not giving you doubts because i'm not sure if we are on the same page. here is a little more of a typical guitar circuit and it represented graphically not schematically. just to keep things clear.
On closer examination, a question comes to mind. Mind you, I'm omitting the tone pot, so just 2 humbuckers, 1 volume w push/pull, a toggle, and the output jack are being used.
I noticed that you have the positive from the p/u selector toggle going to the switch on the pot. Normally, as I understand it, it would go to the #1 pin (left lug) on the pot. So, am I to presume that the resistor #1 (330K) is the jumper that routes the signal from the "up" position (Volume Cut), but when the knob is pressed "down" (Full ) all of these resistors are bypassed?
I'm just trying to understand "how" the routing works is all.
yes. the resistor allows a voltage drop before it gets to the pot. if it weren't for trying to keep the right load on the pickups that's all you'd need, the second resistor along with the pot itself help pull the voltage down and the final outcome is still a 500k load so the pickups shouldn't sound very different. i could have put the circuit after the pot but the reisistor values would have to be high to get a linear sounding control..
when you push the switch it shunts the resistor onto itself which uses less pins on the switch than redirecting, the resistor on the other side of the switch it taken out of the circuit when it is pushed.
