Dan0 said:this might better represent how it goes together.
TonyFlyingSquirrel said:Dan0 said:this might better represent how it goes together.
I apologize, but I'm not well versed on how to read those type of schematics. I'm used to reading the ones from Seymour Duncan and Dimarzio.
Dan0 said:TonyFlyingSquirrel said:Dan0 said:this might better represent how it goes together.
don't apologize. i'm not sure if i'm trying to be too precise. i hope i'm not giving you doubts because i'm not sure if we are on the same page. here is a little more of a typical guitar circuit and it represented graphically not schematically. just to keep things clear.
Dan0 said:here is a little more of a typical guitar circuit and it represented graphically not schematically. just to keep things clear.
TonyFlyingSquirrel said:Awesome, easy shopping list with change for a Big Gulp.
Just 2 resisters: 470k & 51K & about 10 minutes with a solder iron.
Thanks so much for not only your expertise, but your time too.ccasion14:
I greatly appreciate it.
Dan0 said:TFS!!! i think i made a mistake... i beleive -10db is 1/10 the power, not voltage. funny thing about ohms law, if you half the volts the current half as well and the power is down to 1/4. i should have taken the square root of the change in power to get the voltage divider ratio...
what that means is what i listed as 3db is actually 6. what i listed as 6 is actually 12db and 10 is 20db. that might be too much, that's like unplugging from your 100watt amp and plugging into a 1watt amp!! lol... for 10 db you would want more like 340k for R1(330k is available) and 230k for R2 (220k is available or you can make 235k with a pair of 470k)... oops.
Cagey said:My god, man! How could you be so irresponsible?
Where's my gun...
Cagey said:Chicken in the fridge? Breasts, perhaps? Here's an idea. If you've got a meat mallet*, pound the little rascals flat to around 1/2" thick. Fry up some bacon. Set the bacon aside, and keep the delicious smoked pork fat hot. Drop the flattened breasts in the hot fat, about 3 minutes on one side and 2 on the other. Pull those off and drain the fat, but don't wipe the pan. Return the breasts to the pan, put some BBQ sauce on them, lay the bacon on top, then cover with shredded mozzarella cheese. Put the pan under the broiler for a minute or so. Garnish with chopped scallions. Serve with your choice of two sides. I'd suggest buttered rice mixed with sweet peas, and some sort of apple thing. If that don't get you laid, then you may need to shower more often.
*If you don't have a meat mallet, the base of a heavy water glass will work as well.
