Jack fitting issue. Warmoth 3/4” side jack rout on jazzmaster body.
zackjames
I ordered a Jazzmaster body and a mono switch craft jack and during the assembly of a build ran into the problem that the jack didn’t fit in the hole that was routed, the diameter of the jack was too wide. Is there another option that works better?
You can bend the lugs on the jack a little with a pair of pliers to get it to fit.  Just be reasonable in the amount of force you apply and you'll be fine.
