alterbridgefan
It's a flucking input jack. You put the cable in the jack.
:blob7:
:blob7:
Jumble Jumble said:See also the power inlets all over the walls in your house. Wait, you call them outlets? Why?
Jumble Jumble said:Basically what it boiled down to is that "input" doesn't mean "female".
SustainerPlayer said:Jumble Jumble said:Basically what it boiled down to is that "input" doesn't mean "female".
No - to be fair. Most females are associated with output. :doh:
AndyG said:SustainerPlayer said:Jumble Jumble said:Basically what it boiled down to is that "input" doesn't mean "female".
Not in audio. Look at any microphone cable, snakehead, recording console, etc. The inputs are all female, and the outputs all male.
Not really ... just trying to bring some historical perspective as to why someone could mistakenly call a 1/4" female jack an input when it's an output.Jumble Jumble said:AndyG, your point appears to be "a female is always an input, except when it's not". I guess I can't argue with that, but equally in not sure it helps.
[Computing though? Molex, VGA, DVI and all those 3.5mm jacks on sound cards say hi.]
SustainerPlayer said:AndyG said:SustainerPlayer said:Jumble Jumble said:Basically what it boiled down to is that "input" doesn't mean "female".
Not taking about audio ... :redflag:
Dan0 said:SustainerPlayer said:AndyG said:SustainerPlayer said:Jumble Jumble said:Basically what it boiled down to is that "input" doesn't mean "female".
you hand picked examples that seem to match that formula. a speaker jack on an amplifier is female, is that in input? most interconnects are male/male between componants. does the cable ouput on both ends? female input might be true of xlr but it is not true of all audio.
Super Turbo Deluxe Custom said:the ream has to be bigger than the cable it's servicing.
mullyman said:Super Turbo Deluxe Custom said:the ream has to be bigger than the cable it's servicing.
That's what I told her.
MULLY
