India Ink
fretless
So I jumped right in , soon as I saw it on my test piece which is a Stew mac sanding block I knew I'd do it . This stuff dries almost as fast as it goes on and doesn't wipe off .
That is one coat , I used a foam brush and it took about 5 min . It dries so fast I could finish it today but I gotta run for now . I did finish my test piece though , one quick wipe of Shellac and one quick wipe of Min Wax wipe on poly . I think this is exactly what I was hoping for . I'll finish it up tomorrow . Cheers. oh talk about quick , easy and cheap, this takes the award . Also it thins with water , cleans up with water and it has shellac already in it so it seals as well . None more Black
finished
in the Sun
Looks nice!
And you have enough ink left over for another 40 guitars, if my guess is right.
Does it smell like turpentine?
I'll keep this in mind. If i do another body or scratch body, this seems like its about as easy as oil on pretty woods. What if anything is going on top?
not at all , no smell . It does have shellac in it but i don't smell it . I will top it with more shellac and Minwax wipe on . I did just buff it with 0000 steel wool and did another coat and it looks killer .
Turpentine was a reference to "Love Potion #9". But I'm interested to see the last coat.
Nice. Is that fingerboard ebony, or has it too been ebonized? I'm curious to see how india ink does on maple.
Thanks Fellas ! This stuff worked great . I bet it would work or any wood with the same ease . That neck is a Showcase neck I picked up a few years ago when they did the Gibby stuff . It is an Ebony finger board . This is the 3rd body for the neck now and it finally feels right . Great balance ( perfect ) couldn't say that about the SG it was on and while simple it's got what it needs  killer tone and great balance . :glasses9: Cheers
just FTR, i looked up ebonizing maple. I was a bit surprised, as India Ink is a pigment, and maple is very dense and closed grained. It seems that for the piano black finish, India Ink is acually a good method, The primary caution is about not knocking the pigment off corners when sanding.
mm hmm , and it didn't seem to knock any off when I did it . It can be touched up and blends flawlessly  if you have too .
For another application -  I had good luck using india ink on an ash body and sanding way way back so the grain would be really, truly black, and then I dyed the sanded-back body orange.  I think you'll agree the high-contrast grain looks good:
