I put together my build several months ago. I noticed an intonation issue at the time, but figured I'd give the guitar a few months to settle in before trying to tackle again. Well, it's still having the issue. This is a soloist body with a conversion neck and Floyd. My problem is that the intonation is wildly inconsistent. Far more than any guitar I have. When perfectly intonated on the open and 12, the first fret is about 8 cents sharp and the 22 fret is about 8 cents flat. It steadily goes from sharp to flat as you go up the frets.
Nut height seems fine. If I do the 3rd fret check, the string is practically lying on the first fret. I've just got a little bit of relief on the neck. I'm pressing as gently as I can on the strings while checking.
I don't expect perfect intonation across the fretboard, but none of my other guitars are even close to being this far off. Anyone got any idea of what's going on?
