My last Warmoth project was a alder strat body with floyd. The neck was standard thin quartersawn maple with ebony board and 6105 SS frets. The neck weighed a ton despite being standard thin.
Now the guitar has incredible tone, string definition, and cuts through in a band situation better than any other guitar I own, but over the last few years of playing it I've come to wish I had planned the weight balance better.
The neck tends to dip because it is so heavy and I spend extra effort holding it up. I extended the strap screw a bit and that helped, but still an issue.
I suspect the ebony board is adding weight. I'm glad I did not opt for a heavier neck wood!
Next time, I'll probably use pau ferro vs ebony and maybe try the soundlock tuners by Sperzel (5 oz vs the normal 8-9). Then maybe, I'll just lightly finish it with tru-oil.
Anyone have any other tricks to planning a good balanced guitar?
