OldManRiver said:
			Sorry, I guess I explained the neck screw protrusion issue inaccurately. With the combination of the contoured heel and neck screw holes drilled straight down (unavoidable, I know), the heads of the neck screws stick out a little high on one side. The screws are not bend at all, and I was not using a power drill or anything similar. Just a regular, old, correct size screwdriver. I think that maybe they weren't in all the way, just really close, because like I said, they were pretty tight as I was getting them farther in. I didn't keep them in, though. I just wanted to see what the body and neck paired together looked like. I took the neck off just a few minutes after.
That's actually a Good Thing. That means the threads are already cut, so the next time you run the screws in you won't have to fight so hard. I'd still wax them, though, so you don't abrade the wood and open the hole up any more, loosening the joint.
This is one of the reasons some guys (like me) prefer threaded inserts in the neck heel. It allows you to use machine screws instead of wood screws, so there's substantially less wear and tear on the neck if you take it on and off more than a few times during its useful life. It also makes for a tighter joint, which almost has to be a Good Thing as well. Based on your experiences so far, that may be something you'd want somebody else who's done it before to do for you, if the idea appeals. It's a bitch to fix if it doesn't turn out right, assuming it's even fixable, so... word to the wise.
