fdesalvo
I learned something from my last amp build that I was able to apply to the guitar I just built. It solves this problem:
You have a Single/Hum pickup configuration, but only one volume pot. Your humbucker wants to see 500K Ohms while your singlecoil wants 250K Ohms. What do you do? :dontknow:
Why, you employ your friendly neighborhood voltage divider is what you do! Without going into Ohm's law or any other physics hibbity-jibbity, you simply:
1. Remove your control cavity cover.
2. Locate the solder lug on the pickup selector switch that's occupied by the singlecoil's hot lead
3. Solder a 500K Ohm resistor from this lug to ground.
A. 1/4 watt - 1/2 watt will do. I used a 460K resistor I found lying about.
4. Close her up and enjoy! :icon_biggrin:
Voila! Your single coil will now automatically see ~250K Ohms every time you select it. Your other pickups will see the same resistance as before.
