I'll say upfront that wiring is not my forte'.
I'm currently exploring options for a HSS setup using Seymour Duncan passives.
I've explored a bunch HSS wiring options but none deal with Stack single coil pickups.
My plan is to use JB or Custom Custom as the bridge pickup and STK-4S for stacked singles.
However, if they are too much hassle to wire I'm okay with classic singles.
Original idea was to use a 5 way switch, a Megaswitch Type E which would provide following combinations.
1. HUM
2. HUM-SPLIT + Middle SPLIT
3. HUM-SPLIT + Neck SPLIT
4. Middle + Neck
5. Neck
Unfortunately, true single coils are assumed. Sure I could wire STK-S4s as single coils but that would defy the whole hum canceling deal.
I'm aware of the superswitch and trying to stay as far away as possible because figuring that out literally blows my mind lol
I guess the question is, should I bother with these hum-cancelling single coils if wiring simplicity is the goal?
Is there a simple way of wiring them with humbucker without a Superswitch? (ESP ST-1 has this exact set up with a 5-way switch)
If not, I'll just opt for classic SCs and readily available HSS wiring diagrams.
1. HUM
4. Middle + Neck
5. Neck
