Krasson
Hi everyone,
I need some help as I am painfully new to guitar wiring and have a very ambitious project. Is there anybody that can check my diagram and tell if it is correct or if there are mistakes or if the whole thing is just ridiculous?
I'd like to wire up the 3 pickups so that each Humbucker pickup is switchable as follows:
Humbucker series
Humbucker parallel
North coil
South coil
The bridge pickup will then be switchable to reverse the polarity
Then I'd like each pickup to get an on off switch for which I am using DPDT switches. After that the Volume and Tone knobs will be connected.
I tried to match the color coding to my lace sensor finger burners:
Humbucker
Orange = North Start
White = North finish
Brown = South Finish (originally black and orange)
Gray = South Start (originally black and white)
Single coil
Black = hot
Gray = ground
Green = Ground wire
I copied the wiring diagram for the Humbucker switches from this website: https://www.premierguitar.com/diy/mod-garage/triple-shot-humbucker
I'l be glad about anything you can tell me.
Cheers
Humbucker series
Humbucker parallel
North coil
South coil
Humbucker
Single coil
Black = hot
Gray = ground
Green = Ground wire
Cheers
