stratamania
Mythical Status
Can you post some photos of the actual wiring?
thanks alot man, i added the blue jumpers and it seems that it was the missing link. all five positions work now.
heureka, that was the issue! switched the two wires, now position 2 sounds fantastic too! many thanks!!!!
That is not optimum. I also do not know where you have made those connections or any others for that matter.Two things come to mind that I might have done wrong. I have green and bare twisted together and soldered to the switch. Is that correct? And then I run another wire from that same point to ground on tone pot. On the diagram that is the green line.
The other thing is the wire to volume in passes through tone pot first, instead of other way around, not sure if that matters.
Thanks, I am going to do that, start over with a fresh switch and follow your advice. Just one more question about the green/bare wire from the p-rail; Is it green only to switch and bare to ground?View attachment 64124
The key is above. On SD wiring for humbuckers Green and bare are usually joined to ground. They could both go to one of the terminals of the switch and then use a single covered wire to a common ground point. All your ground points need to have continuity with each other.Note: the previous version may be better if wanting to incorporate additional switching post the selector switch, such as out of phase as in this version bridge green and bare go directly to ground. That said, a phase switch for the bridge green and black could be pre selector switch and the bare in this case go directly to ground, bypassing the phase switch.
Success! Thanks again.
