WindsurfMaui
How much should I turn a truss rod on a new neck before I install it on a body so I will have a straight neck once it is strung?
I like my necks to be as straight as possible. I also prefer to use the side adjustment for only a slight tweak. So I have a new Warhead Gibson conversion neck Mahogany shaft with a Rosewood fretboard in a fatback profile. If I'm going to put on 9.5 or 10 strings how much should I turn the truss rod before I attach the neck to the body? Is there a rule of thumb anyone has found through experience? I really don't want to string up the guitar only to have to unstring it and remove the neck to get the neck 99% straight before I use the side adjustor for the last 1%. Thanks.
