One other thing about that excursion limit - if you cross over the Beta 8CX at 200 Hz you can take it all the way to thermal limit (about 119db which should be plenty paint peeling for any normal use)
I'm still thinking about building my FRFR with a "sub" for use with drum/bass monitor and only take the 8CX when I just need it for guitar. I have an offlabel Eminence Delta Pro 15 - which is xmax limited, but I can get it in a reasonably flat box and take the xmax limit up to 118db @ 62 Hz, with a -3db point at 47 Hz which ought to pack decent punch for a bass and drum monitor - at least up close. (If you're talking about using it as a stage/room filling monitor - that 118db @ 1m drops off to 104db @ 10m, which doesn't leave a ton of headroom for deep bass drum transients. If you figure you want 10db peak over the average level - it's adequate for rehearsal with electronic drums. It doesn't really do justice to my 32" marching bass drum though)
