Hey, I need some help and opinions :)
MicahC
I looked for a bunch of guitars and I didn't really like any of them. Then I found warmoth  :toothy10:
Please tell me your opinions on the guitar, even though it isn't my reason for posting.
And, if you would, I couldn't quite figure out what some of the stuff on the order form meant  :tard: So the stuff with a "?" means....help?
Thanks
Body Style / Shape: Carved top Soloist
Body Wood: Mahogany w/ flamed maple top
Type of Bridge or Tremolo: Schaller Floyd Rose
Control Cavity: Rear rout
Pickup routing configuration: HSH
Pot hole locations:?
Switch slot:?
Jack hole diameter:? what is the standard size?
Other instructions pertaining to this body: I want both of the comfort contours, a Floyd Rose tremolo routing, and the contoured heel.
The finish will be dyed purple with a burst And the back of it being black, but where do I put it? In the "Finishing Instructions'?
thanks for the help  :icon_smile:
As I could not explain very well with my not very rich english, I hope this helps:
http://www.warmoth.com/customerservice/orderforms/order5.htm
http://www.warmoth.com/customerservice/orderforms/order42.asp
But I have done in a Word doc and they didn't felt any bad (or had not told me  :icon_biggrin:)
But I didn't found it when I were buying, beside I always knew it exist...
You probably need to hang out here for a while more... look at the gallery pictures here and on the Warmoth site and then give them a call - they'll answer all your questions.
The pot and switch in carved soloist are this, alike rear routed Strats:
http://www.warmoth.com/guitar/bodies/soloist.cfm?fuseaction=soloist_control
You shoud specify all them or the ones that you one or no one, and make your own... and the kind of switch, too...
Jack: ask for the 3/4", if I'm not wrong...
on Nº5 say: recessed floyd rose or non-recessed... the one that you wish...
Countored heel, number 11, confort contours I believe in the box other instructions...
Paint: Say it "clearly":
top: purple dyed burst (you'd better say the size of the burst...  http://www.warmoth.com/paint/paint.cfm?fuseaction=dye_purple)
back: solid black
any doubt they will ask you...
I will do that
Thanks to you both alot, and especially you NonsenseTele. I'll be here awhile....lurking :cool01: Thanks
When you are ready to order, I would recommend doing so by phone.  The sales rep can talk you through a lot of the little details and tell you what works with what, and what doesn't.
Thank You! That was my very next question  :toothy10:
Yea, I have had a lot of success calling them. I always feel bad because I go on and on with the questions, but the dudes at Warmoth are really patient and helpful!
