reluctant-builder
I don't know how to preface this except to ask that you please look at these photos and tell me if this is a real problem and, if so, what is causing it and how -- if -- it can be fixed. Thanks.
There's a lot more room between the low E and the side of the fingerboard than between the high E and its side of the neck. The clay dots are not centered between the G and D strings.
Top clay dot is not between the A and D strings.
Looks semi-decent at the nut:
String spacing is off over pole pieces of the neck pickup:
Spacing looks fine over the bridge pup:
