tfarny said:I have a minimass, it works well but not as well as just getting a 5 or less watt tube amp.
=CB= said:May I respectfully say - I"ve had less than stellar results with the Mass, from Weber, and have been asked to fix several that were fried when they should not have been.
May I also respectfully say, running the Yellow Jacket, and EL84 tubes is the bomb... an absolutely wonderful thing. A 50w amp will give you about 10w that way, if you run both tubes. I'll have to check, but there is a way to cheat, and run a single Yellow Jacket, leaving one output socket empty on the head, and get about 5w out - still plenty loud, but not outrageously so.
Vic has run his Champ with a drummer, and his Hot Rod Champ (2 x 6v6) is more than adequate for that at 18w
A few watts will give you a lot of loud.
NLD09 said:what does boot its baws mean?
elfro89 said:the yellow jacket idea is cool... But I need the clean headroom for larger venues and 10 watts won't give me that unfortunatelyI just need a way to push the amp at lower volumes for home and small gigs without it sounding thin.
In short... I want to boot its baws at lower volumes.
Superlizard said:Correcting what I assume to be an oversight (for posterity's sake):
Some ppl. are claiming Yellow Jackets will get you 10 watts.
Not so - a single EL84 t00b produces ~9 watts.
Paired up of course (they sell in pairs) will get you ~18 watts.
elfro89 states his amp is 50 watts - undoubtedly with a pair of powert00bs.
So, if he does the YJ route, he's going to be pushing 18 watts; which isn't
a whole bunch quieter than 50 watts. As I've mentioned before, it's still
pretty fuggin' loud. I run a Hotplate on top of that as well.
OzziePete said:Just to confirm this : I own an 18 w amp combo which has 2 x 6V6 power tubes, lots less potent than 6L6s, but it still kicks my butt volume-wise. So much so I bought an Iso Cab and ran a feed out of the combo into the Iso Cab and shoved the Cab into the wardrobe for good isolation and very much lower volume.
For the record, I'm not much of a fan of the attenuator .
Superlizard said:OzziePete said:Just to confirm this : I own an 18 w amp combo which has 2 x 6V6 power tubes, lots less potent than 6L6s, but it still kicks my butt volume-wise. So much so I bought an Iso Cab and ran a feed out of the combo into the Iso Cab and shoved the Cab into the wardrobe for good isolation and very much lower volume.
I like attenuators, but only up to a certain point of attenuation... after that (higher attenuation) the tone becomes flat mush.
I've considered the iso cab route myself but never researched it fully.
Which iso cab are you using?
