androideyes
i picked up a squire strat at a pawn shop the other day and i want to do something ridiculous to it. ive settled on getting a custom made pickguard, routing out more of the body, and dropping four of the seymour duncan lipstick pickups in it.
the pickups are made for strats so they come in neck/middle/bridge configuration with the middle being reverse wound/reverse polarity. i figure i can get the full set and double up on the middle pu.
then, wire the neck and middle pu closest to it to the stock five way switch and wire them up so it's, position 1: off/the middle coil/both on in series/neck coil/position 5:both on in parallel.
then do the same thing with the bridge and middle pu closest to it and wire them to a five way rotary toggle in place of the master volume.
since i'm not a fan of tone knobs, i could then convert the tone knobs into volume knobs. one for each toggle switch. then wire those to the output jack.
it should look cool and be a twangy tone monster!
in my head this works beautifully but i haven't done anything this complex in reality. anyone see a flaw in this plan or something i should watch out for? i'm thinking the grounding will be a birds nest for sure.
