I'm looking to build a tele deluxe with Telenator's wide range recreations. This is the thread where the pickup development is documented. http://www.tdpri.com/forum/just-pickups/102490-fender-wide-range-humbuckers.html.
In this thread, the first iteration Telenator made yielded a pickup he really liked the sound of, but wasn't that close to the original wide ranges. He ran this pickup through 500K pots. The final design of his recreations are apparently very close to the originals and sound best through 1M pots. I'd like to get one of each of these pickups in the same guitar. The ideas is to run one set of 500K pots for tone and volume of one pu and a set of 1M pots for the tone and volume for the other pu. Looking at the standard tele deluxe wiring diagram, it looks like the switch isolates the two pickups and that the signal doesn't go through both sets of pots (except in the middle position).
http://support.fender.com/diagrams/telecaster/0137702A/SD0137702APg2.pdf
My question for you guys, will this work in recreating the two sounds in the same guitar, or do I need to come up with an alternate way to wire it?
