H-S-S 1 Volume 2 tones 5 way. Ground questions? output Jack and trem does the ground go on both?
ZGOZZ Senior member Messages 632 Oct 23, 2008 #1 H-S-S 1 Volume 2 tones 5 way. Ground questions? output Jack and trem does the ground go on both?
B bpmorton777 Senior member Messages 1,651 Oct 23, 2008 #2 yes every part needs to be grounded. pots, switch, pickups, jack, trem Brian
ZGOZZ Senior member Messages 632 Oct 23, 2008 #3 bpmorton777 said: yes every part needs to be grounded. pots, switch, pickups, jack, trem Brian Click to expand... Ok cool.
ZGOZZ Senior member Messages 632 Oct 23, 2008 #4 So from the pots to sleeve ground on the output jack then from the pots to the trem also?
