But still...
You sure we can't change your mind? I have that exact one (the right one :icon_biggrin
on my seven-string, albeit with series/cut/parallel switches. I'd say 50% or more of the time I've got both pickups on and one switched. I'll give you another on/on switch if you want, I bought a whole boxcar of 'em some time for some damn reason or another, ah the mists of time. :dontknow:
You couldn't do neck single and bridge hum, neck hum and bridge single, neck and bridge single, or neck and bridge hum. For this reason, I'd do 2 SPST or push/pull pots. The split coil sound, although a single coil, lacks the sound of a true single coil and is best used in conjunction with another pickup.
