jackocaster
I am finishing up on my new warmoth strat. I thought I had the wiring thing covered, but I guess I was wrong. I am still getting a buzz that goes away when I touch the bridge. Bad ground, right? I'm not sure what is wrong.
I have the cavity and pick guard covered with copper. I soldered the joints in the foil and left about 1/8" on top so that the pick guard comes in conact with the body copper. I sanded down the volume and tone pots to get a good contact. I have Fender SCN pickups and a 5 way switch. I followed the Jeff Beck upgrade wiring diagram and the one that came with them.. I have a wire from the volume pot to the spring claw and one to the body copper (soldered).
I have read about grounding loops, but I don't think I have any. I did not use a screw for the wire to the body. Is that the problem? Also, I am using car speaker wire for my jack.
Thanks for any help!
I will post a picture in the other section when I get a chance.
-Jack
-Jack
