ThePhilosopher
This is quickly trying to kick out the Tele as my favorite body style, I've got a cream colored switch tip on order for the selector.
Green Flake Jazzmaster
Full specs of the Warmoth build are below
Lollar pickups
Gotoh Magnum locking tuners
Mastery trem, bridge and string trees
Tesi Arcade Push button kill switch
Gunstreet Wiring Harness with treble bleed
LazrArt Neck Plate
Lollar pickups
LazrArt Neck Plate
| Construction Solid Core Wood Mahogany Body Upgrades Three Piece Right / Left Handed Right-Handed Control Cavity Top Rout Neck Pickup Rout Standard Jazzmaster® Bridge Pickup Rout Standard Jazzmaster® Jack Rout None Bridge Rout Type Tremolo Bridge Rout Jazzmaster Tremolo w/ Jazzmaster Bridge Mounting Holes Standard 4-Bolt Neck Pocket Shape Strat® Body Contours Forearm Contour, Tummy Cut Paint Category Flake Top Color Green Flake Back Color Green Flake Satin or Gloss Gloss | Construction Modern Shaft Wood Maple Fretboard Wood Indian Rosewood Nut Width 1.650" (42mm) - Vintage Medium Right / Left Handed Right-Handed Neck Back Profile Standard Thin Fretboard Radius 10" - 16" Compound Number of Frets 22 Fret Size & Material SS6115 - Wide & Tall (Stainless) Tuner Hole Size Gotoh/Grover (13/32" - 11/32") Inlay Shape Standard Dots Inlay Material Cream Side Dots White Side Dots String Nut Standard Nut - GraphTech Black TUSQ XL Mounting Holes Standard 4-Bolt Neck Heel Shape Strat® Shape Finish Green Flake |
