I wanted to give back to this board a bit, so here's a post about my adventures with the Graphtech Ghost piezo saddle pickups for solidbody guitars. These are supposed to give a decent acoustic sound option for solidbody electrics, which is really convenient for gigs, obviously.  Apparently more and more pros are using this setup, or the LR Baggs system.  For instance, I read somewhere that Pearl Jam does this now (not an endorsement, but you get the point).  They are saddles for a strat, made out of the graphtech fiberglass-like stuff, each of which has a wire coming out the bottom, attaching to a little internal preamp w/ a 9 volt battery.  It's advertised as being for Strat or Tele, the Tele version having longer intonation screws. It outputs in stereo, so you can use a Y cable to get a piezo and magenetic separate output; attach a normal cable, and it automatically blends the two signals.  Pretty neat on paper.
My plan was to install this in the Nashville Tele I'm building, about which there's a thread in the DIY finishing section. Unfortunately, telecasters have a really small control cavity (who knew??). It's almost as if whoever designed the thing didn't even stop to consider the possibilities of active electronics! Graphtech is verging on false advertising selling a "Tele" version and giving instructions for routing the little wires through the Tele bridge plate. My plan was to use a concentric pot for master vol / tone for the mag pickups, and the second pot for the piezo master volume (it would be 'always on', just turn off the volume to take it out of the mix). With that control setup, there's no way in hell you can fit a 9v battery and that little circuit board along with all the extra wires. I decided I had three options:
1. Route a battery-sized hole under the pickguard in my new one-piece body (using a hand drill and some router bits), having never done this kind of work before.
2. Give up on the tone control, and go with dual 500k mini-pots (master vol for mag, and for piezo), and try to somehow squeeze it all in there.
3. Install it on my POS partscaster, which is as much a guitar-tech educational tool as it is a guitar, and see if it worked and I actually liked the sound enough to eventually try 1. or 2.
Of course I did #3. The partcaster has already had a hardtail conversion, so there is all the room in the trem cavity to help me out. Honestly, it was a lot harder than I thought; I needed to drill or enlarge three holes in the body, as well as rout little areas between the bridge and the pickguard. I also had to do a total rewiring. As you can see, there's a lot more wire going on here. It's not a complicated thing if you understand basic guitar electrics, but it's more of a project than I expected.
		 - I might try it. For a few decades there, bands like CSN&Y and Yes miked acoustic guitars onstage in stadiums, quite successfully - now even the Grand Ole friggin' Opry has gone piezo; they (quite successfully) mike the dobros, fiddles & banjos, while the "acoustic" guitarists wobble around quacking and fizzing like plasticine robots. Don't you just wish Dave Matthews would buy a real, electric, Telecaster and a Twin Reverb and spend six months learning how to sound GOOD?!? Unless you're Eliot Fisk, John McLaughlin or Paco De Lucia acoustic guitars suck anyway. :binkybaby:
