SuperWideHeaven
Hi there,
did anyone installed Graph Tech locking Tuners on a Warmoth Stratocaster replacement neck and can give some advice how to install them?
I bought these 6-in-Line Graph Tech Ratio locking tuners:
https://graphtech.com/collections/ratio-machine-heads-electric/products/ratio-electric-locking-machine-heads-6-in-line-prl-9721
The Graph Tech Tuners got 2 very short pins (not as long as the Fender locking tuners) and come with so called Invisiomatch plates to fit existing holes of tunes that are replaced. But how to install these tuners on a "new" Warmoth headstock?
On Graph Tech Website I found these Invisiomatch Plates for Fender. But they're not supplied in the 6-in-Line Package:
https://graphtech.com/collections/ratio-machine-heads-mounting-plates/products/ratio-plate-for-fender-sty-2-pin-hole-bk?variant=31625845178391
The 6-in-Line Package comes only with these plates:
https://graphtech.com/collections/ratio-machine-heads-mounting-plates/products/ratio-plate-for-45-degree-screw-hole-blk?variant=31613197385751
https://graphtech.com/collections/ratio-machine-heads-mounting-plates/products/ratio-plate-for-90-degree-screw-hole-blk?variant=31613391601687
https://graphtech.com/collections/ratio-machine-heads-mounting-plates/products/ratio-plate-for-gibson-screw-hole-blk?variant=31613185720343
https://graphtech.com/collections/ratio-machine-heads-mounting-plates/products/ratio-plate-for-f-style-screw-hole-blk?variant=31613118119959
Why the plates for fender are missing in the 6-in-Line package? Are the Tuners supposed to be installed without plates even if its pins are so short?
Can somebody help?
Best regards,
Bernd
Can somebody help?
Best regards,
Bernd
