C
Cederick
I wanna use a Gotoh Floyd for some possible build soon but it bugs me that the block is 41mm and slightly too long for regular recessed bodies and paying for a FU Tone shorter block from USA to Sweden will only be a big expense.
So I thought, maybe cutting up the slots where the springs are attached? That would at least make the springs come up to the desired height so that that springs can be straight in the cavity
And if the block would be a bit too long I could just "dig out" the back cover a bit so it has room to move.
This seems to me the easiest way to make a free conversion, since I don't have any metal router at home, but I do have a saw I can use. Also another good thing is that this will keep most of the mass of the 41mm block and therefor have good sustain (even tho I don't think a few millimeters really do THAT much of a difference in real life)
