CrackedPepper
As chronicled in two threads (here and here), I have a goncalo neck with serious buzzing issues on the 6th, 5th and now sometimes 4th strings. The buzzing is evident thru my amp. I hit strings pretty hard but they buzz with even medium force (for example, just using my thumb).
I've spoken to Rob the sales manager at Warmoth and he suggested the following to track down the buzzing:
With the help of my daughter, I've narrowed done the buzz to the 21st or 22nd fret(s). Both frets appear to be seated correctly. In addition, the frets have been leveled & dressed professionally and the guitar has gone through at least two professional setups.
Before I send it back to Warmoth, does anyone have any other suggestions? I really don't want to go through the trouble of taking off the neck and shipping it back let alone being without my guitar but I am at my wits end.
- Make sure it is not the nut and trees by deading the string above the nut with some foam - it's not
- Make sure it is not the strings by deading the springs with some foam - it's not
- Make sure it is not the saddles/adjust the string height - doesn't seem to be and the saddles are basically as high as they can go
- If I can't track it down then I can return it for "evaluation"
