Oh, my bad, well the special has zinc saddles too. But the OFR has a hardened bridge plate and posts as well as steel saddles. And the 2-7/8's spacing they say is wrong, I have 3 of them from GFS, and they have the same as the OFR post spacing as any other 2.91.DMRACO said:I am not using recessed. I believe he saddles are steel. Only mentioned the studs being zinc. The spacing seems off. 2 7/8 does not equal 2.91.....the measurement for an OFR. I will take you word for it since you are the expert.
That's what i'm guessing, they just eyeballed it with a tape measure or scale, and just called it 2.875"... :dontknow:Dan0 said:the difference between 2.91 and 2-7/8 is .035 which is just under 1mm (.0394) it's not machinist precision my any means but as long as one of the blades on the bridge are strait and they usually are you probably wouldn't notice any problems.
chances are actually that they measured it wrong in the advertisment. on a ruler 2.91 would look like 2-7/8 since .035 is about half the smallest measurment on a typical ruler.
ZionWarmoth said:I use the GFS fast-loader, it's wider than the original Floyd-Rose I have it in a couple of guitars, love that you just use regular strings, no more cutting strings end balls, and works very well, the only I changed is the block
DMRACO said:ZionWarmoth said:I use the GFS fast-loader, it's wider than the original Floyd-Rose I have it in a couple of guitars, love that you just use regular strings, no more cutting strings end balls, and works very well, the only I changed is the block
any issues with it going out of tune with big dive bombs??
