vikingred said:
Mayfly said:
You probably need to have something in the split to keep the split from collapsing when you tighten the screw on the knob. I find a little piece of tie wrap works fine for this, but anything that's the same width/depth as the slot will do. Based on your assertion that you broke off a tab, this is probably your problem.
Or as others suggest, you could just use a solid shaft pot. You're putting a new one in anyway.
Yeah I botched it. I'm about to start redoing the electronics right now and give it another shot.
It's almost 2 years since you last posted in this thread, but I'm keen to know how you went. I'm curious about this topic and googling this issue I stumbled onto your problem here.
Just for defining terms, so there's no confusion, I'll refer to the "
bushing shaft" as the initial part of the potentiometer column, that the bushing nut is screwed onto, so that the pot can be secured to the guitar body – it is NOT the actual section that the knobs are attached to. I will call the "
knob shaft" that smaller end section after the
bushing shaft on the potentiometer column, where the knob is actually inserted and fitted onto, which maybe either "knurled" (i.e. split shaft) or "solid". God, that was horrible and I'm glad definitions are over!
I'm very keen on Schaller Dome knobs, which have a 6mm diameter
knob shaft hole in them – I'm yet to find out if there are any spline shapes inside though. I'm looking at Bourns Premium 95 pots, which are available in a "long"
bushing shaft (3/4" length) and a shorter "standard" length
bushing shaft (unsure of length as yet) – both are available in 6mm
knob shaft diameters. Unfortunately, only the "standard" length
bushing shaft has an optional solid "
knob shaft". I am not sure if the "standard" bushing length pot, is long enough to fit in the rear control cavity of my telecaster guitar body (too close to call, but I bet on "NO!"). Like you have found in general, the "long"
bushing shaft pot does not have the option for a solid
knob shaft, which is really annoying!
It sounds like
knob shafts, that are knurled, are a piece of junk, but I don't know and I would like to. I have read from others, but not here, who have stated they cannot be secured without movement (i.e. like you've reported). Maybe this is a spline issue on the
knob shaft with the hole it's inserted into, but I don't know much about this as of yet. In any event, I keep hearing knurled
knob shafts are very easy to break when bent and that happened to you too! I'm inclined to think they are terrible, because the split
knob shaft has no strength and gives way at it's very centre? I did notice that the Bourns knurled
knob shafts, have splines on them; maybe there are also splines inside the knob hole and they are incompatible? Is it possible the shape of the
knob shaft and the shape of the knob hole are incompatible? If they are the same shape, then it appears knurled shafts suck and the only option to strengthen it, is to chock the split.
I'm not interested in anything but the Bourns pots and if it has to be the longer 3/4"
bushing shaft option (with no alternative but a knurled
knob shaft), then I wonder what would be the best way to fill/chock the split in the
knob shaft.
There is also another factor to consider, apart from knurled
knob shafts and/or splines and that is the shape of the top of the
knob shaft compared to the bottom of the shaft hole in the knob (where they both meet). If they are different shapes, it would be a problem, particularly if you have a collapsing knurled knob shaft!
