Soloshchenko
Hi guys. As said in the title apologies if this has been asked a million times before. I've done a fair few searches and not quite found the exact answer I need.
I've recently stripped a second hand P Bass body down to bare wood and want to refinish with a wood dye as the wood underneath is quite nice and it was so cheap I want a really cheap finish for it.
My idea at the end was to go over it in tung oil to finish it. At the minute the process I'm going for is this:
1) Apply sanding sealer.
2) Sand back to a fine grain
3) Apply a coat of water
4) Apply black wood dye (grain enhancer)
5) Sand back again
6) Apply another coat of water
7) Apply a blue dye
8) Sand back
9) Apply a second coat of blue dye
10) Sand back
11) Tung oil finish
Now, I'm sure I have this wrong somewhere! My question is, would the above process work? Would it give me good results? Have I got the order totally wrong? Is there anything else you would do?
Any input is really appreciated Warmoth finish gods! Cheers.
5) Sand back again
7) Apply a blue dye
8) Sand back
10) Sand back
11) Tung oil finish
