Wasn't sure which forum this should go in so I am dropping it in general. Should you install ferrules before or after you finish the body? I know that if you do it after you have to clean out the holes. I figured if you installed them prior to finishing you would have a nice tight fit and wouldn't have to clean out the hole. I am using the tru-oil finish if that makes a difference.
