LouSiffer
Just a heads up. I buy USA Fender bodies and use Warmoth necks because I like wider necks than Fender offers. I am currently putting together a new Fender Professional II body with a Warmoth Modern neck. If you do this, 1 of the neck screws runs directly into the truss rod adjuster on the side of the neck. You will need a shorter screw ( 33m in thread length vs the standard 41mm or 37mm overall length vs 45mm standard.
These bodies have an tapered neck pocket with an offset screw hole to allow easier access to the upper frets.
