Hello all,
We're now announcing the February, 2013 Guitar of the Month contest! February's contest will be "OPEN" to all finishes, but still require at least a Warmoth neck or body to qualify.
Please read the GOM rules, which have been refined, with some slight changes, and are posted in a sticky in this forum area.
Submissions must be sent, to uwfgom@gmail.com, and contain two images no greater than 1024x768, along with your description and details of the instrument.
In turn, those images will posted to this message, which is February's submission thread.
Submissions will be accepted from now until to February 7th, so get your cameras clicking!
As usual, all discussion for the submissions can take place below, along with other pictures hosted by the poster.
Good luck, and may the best guitar/bass win!
Guitar #1: by Greg McCullough
Chambered black korina
Black korina neck
Macassar ebony fingerboard
Abalone dot inlay
6150 frets
Gotoh vintage tuners
Duncan 'Antiquity' pickups
Vintage Fender bridge
Q-parts white pearl knobs
Woodburned & finished w/Tru-oil
Guitar #2: by jmavl
Found this alder strat copy in a pawn shop and brought it home for $50. I trashed everything but the body... all other components are new. I did all the relic work on the finish, and reassembled with Texas Special pups, vintage tuners & a mint green pickguard to have a 50s appearance with a crunchy, bluesy bar room sound. All hardware, except the bridge, is nickel and has been reliced using muriatic acid.
The neck is Warmoth vintage modern: One-piece maple, std thin contour, 6105 frets, clear satin finish. I did not relic the neck.
Guitar #3: by ChristianFS1
Item Number: PS6607, Stratocaster®, Right handed, Alder, Top Rout,
Pickup Rout: (Strat®, Strat®, Strat®), Lindy Fralin Vintage Hots Set, Bridge: Vintage 6-Hole
Tremolo, Jack Rout: Strat® Top Jack Rout, Top Finish: Daphne Blue
Stratocaster®, Vintage Modern, Right Handed Reverse Handed, Maple, Maple Fretboard, 1 11/16" Nut Width, Standard thin, GD6150 (Gold Color), Gotoh/Grover (13/32", 11/32") Tuner Ream, 22 frets, 10-16" Compound Radius, Black Face Dots Inlay, Black Side Dots, White Corian, Vintage Tint Gloss, 25-1/2 in. Scale, Standard 4 Bolt
Serial Number: PG940975
Shape: Stratocaster®
Orientation: Right Handed
Color: .09" White Solid Gloss
Neck Pickup: Strat
Middle Pickup: Strat
Bridge Pickup: Strat
Control 1: Volume
Control 2: Tone
Control 3: Tone 2
Control 4: 5 Way Switch
Bridge Cut: Standard
Additional: Standard
Mounting Holes: 8 Hole Vintage
Guitar #4: by SolomonHelsing.
34" Scale Bass
Swamp Ash Transparent Purple Body
SD Quarter Pounder Jazz Neck Pick-Up
Rio Grande PowerBucker Bridge Pick-Up
Takeuchi T5 Bridge
Wenge and Bloodwood Neck
6130 Frets
White Corian Nut
Abalone Dots
RotoSound 66 Swing Bass Strings.
Guitar #5: by Pelagaard
Warmoth Bass VI
Neck :
Wenge, Warmoth Bass VI profile
Bubinga fretboard
SS6150 frets
no inlay, side dots only
Graphtech Black Tusq XL nut
vintage tuners
Body :
Black Korina Bass VI body
Deft semi-gloss lacquer finish, no grain fill
Hardware :
GFS Mean 90 neck and bridge, GFS Brassbottom 7k middle
Master Volume, 500k pot
Master Tone, 500k pot, .01uf and .022uf caps in parallel for a total of .032uf
Individual On/Off switch for each pickup
Modified Mustang bridge (the one Warmoth sells)
Standard Jazzmaster tailpiece, spring removed and locked into place
Neck plate from Dangerous6 (black plate with Nautilus x-ray)
Guitar #6: by Updown
All Warmoth Finish on Body, with a Raw neck.
Body ...
Alder (Solid)
Rear Rout H x H
Contoured Heel
High Grade Quilt Maple Top
Black Dye finish on Top
Black Gloss on the Back
Black Burst on Edges.
Hardware...
Tone Pros
Recessed TOM - Angled Strings
Chrome Top & Bottom Ferrels
Bare Knuckles, Mule (Neck) Chrome Humbucker
Bare Knuckles, Abraxas (Bridge) Chrome Humbucker
Metal Black Hum Rings
3 Way Switch with Chrome Tip
2 x 500K CTS Pots
Orange Drop Capacitor
1 x Vol, 1 x Tone
Tele Heavy Knurled Knobs
Neck …
Vintage Modern
Pau Ferro
Ebony Fretboard
Stainless Steal Frets SS6115
1 11/16" Nut width
Graph Tech Black TUSQ Nut
10 -16" Compound Radius,
Standard Thin Neck
Mother Of Pearl Dot Inlay
Sperzel Lok Tuners
Custom Dougie Neck Plate
Guitar #7: by Ddbltrbl
Body:
Black Korina VIP
Clear Gloss Finish (by Warmoth)
BK Mules Pups
Gotoh 510 bridge
All Rosewood knobs, pickup rings and truss rod cover. Wired with pull knobs for coil split and phase reversal.
Neck:
Black Ebony on Wenge, Warmoth Pro Angled w/ Warmoth Headstock
Clapton Contour and no inlays
Planet Waves Auto-trim tuners
SS6105 Fretwire
GraphTech Black TUSQ XL nut
Guitar #8: by Autobat
VIP Body:
Gloss Black
Chambered Mahogany, Maple cap
Original Floyd Rose
Chrome EMG 81X & 85X pickups
Schaller strap locks
Warmoth neck:
SRV Contour
Bloodwood over Wenge
Black face dots, white sides
SS6105 frets
Floyd R4 nut
Grover tuners
Guitar #9 by: SlartiBartfast
Dinky J-Bass
Solid Black Korina back with laminate Black Korina top
Tobacco burst finish
Rear-routed
Dimarzio Model J pickups
1 Volume, 1 Tone control
Gotoh 201 Bridge, Gotoh GB7 tuners
Black GraphTech TUSQ XL nut
1/2" deep panel side jack
Dunlop dual-locking straplocks
Wenge neck (raw, of course)
Pau Ferro fretboard (unique choice)
Lined fretless (22 frets)
Guitar #10: by Death by Uberschall
Warmoth Body:
Flat Top Soloist
Slight brown burst to clear gloss
No binding, clean line to clear Gloss
1-piece Mahogany body
Unique Choice flame Koa top
Contoured heel
HxS pick-up routing
Recessed TOM routing
Angled string thru body
Warmoth Neck:
Warmoth Pro
No binding, clean line to raw finish
Canary neck
Black Ebony board
Warmoth "DbU" headstock shape
Flame Koa veneer from body laminate
1-11/16 nut width
'59 Roundback profile
Straight 12 radius
24 fret extension
SS6100 frets
No inlays/face dots
White side dots
Raw neck back
Hardware:
All black
EMG 81/SA
TonePros TOM w/locking shaft option
Gotoh tuners
Electrosocket
Single volume
CRL 3-way blade switch w/black knob
DR6 Top Notch Crap custom neck plate and truss cover
Black korina neck
Abalone dot inlay
6150 frets
![mccullough1_zpsb5bcb434.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2Fmccullough1_zpsb5bcb434.jpg&hash=72a43e28e358a7dca8ade3e0094450fc)
![mccullough2_zpsbb313788.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2Fmccullough2_zpsbb313788.jpg&hash=020297e6bdf82347fef2cd3fa3401b01)
Guitar #2: by jmavl
![jmavl1_zps79c951f5.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2Fjmavl1_zps79c951f5.jpg&hash=0295b8322e2314214fc248e284636f0c)
![jmavl2_zpsc348c8ba.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2Fjmavl2_zpsc348c8ba.jpg&hash=9ec078300098318bc9bd8fda12485441)
Neck Pickup: Strat
Control 1: Volume
Control 2: Tone
Control 3: Tone 2
![christianfs11_zpse7391719.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2Fchristianfs11_zpse7391719.jpg&hash=933a9d9cb0289d38174f7fe961d965d3)
![christianfs12_zps8b44952c.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2Fchristianfs12_zps8b44952c.jpg&hash=02f8ffd2dc60373252607e10d27b7db2)
34" Scale Bass
Takeuchi T5 Bridge
6130 Frets
White Corian Nut
Abalone Dots
![SolomonHelsing2_zps85dc5b6c.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2FSolomonHelsing2_zps85dc5b6c.jpg&hash=04f9b9dff2d0af78488c53d144a57f32)
![SolomonHelsing1_zps40add68c.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2FSolomonHelsing1_zps40add68c.jpg&hash=c89a8c2ac38143676fd24632fde3062b)
Warmoth Bass VI
Neck :
Bubinga fretboard
SS6150 frets
vintage tuners
Body :
Hardware :
![Pelagaard2_zpsaf57416a.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2FPelagaard2_zpsaf57416a.jpg&hash=331643da3b667e30a2403f5ecf958ac6)
![Pelagaard1_zpsace06bc3.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2FPelagaard1_zpsace06bc3.jpg&hash=4859da8fb31d860fe797b7a09025974d)
Body ...
Alder (Solid)
Rear Rout H x H
Contoured Heel
Hardware...
Tone Pros
2 x 500K CTS Pots
1 x Vol, 1 x Tone
Neck …
Vintage Modern
Pau Ferro
Ebony Fretboard
1 11/16" Nut width
Standard Thin Neck
Sperzel Lok Tuners
![updown1_zps8a9ad856.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2Fupdown1_zps8a9ad856.jpg&hash=c72f25590738b7902a7eac840575b061)
![updown2_zpse3566ca1.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2Fupdown2_zpse3566ca1.jpg&hash=28885f0bb1e27d128882fe3d769ceb48)
Body:
Black Korina VIP
BK Mules Pups
Gotoh 510 bridge
Neck:
SS6105 Fretwire
![Ddbltrbl1_zpsb078045d.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2FDdbltrbl1_zpsb078045d.jpg&hash=5b882dc267fd6a009d531ebdb2fadad6)
![Ddbltrbl2_zps27a80ccf.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2FDdbltrbl2_zps27a80ccf.jpg&hash=42aab0ceb9e0936120636f8d449437f1)
VIP Body:
Gloss Black
Original Floyd Rose
Warmoth neck:
SRV Contour
SS6105 frets
Floyd R4 nut
Grover tuners
![autibat1_zpsf195791c.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2Fautibat1_zpsf195791c.jpg&hash=b36674fc8f19d8870ead0ac1e03e2e29)
![autobat2_zps913ca41a.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2Fautobat2_zps913ca41a.jpg&hash=07379b96a70cf01196d9692d336ad2f2)
Dinky J-Bass
Rear-routed
![SlartiBartfast1_zpsef232a92.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2FSlartiBartfast1_zpsef232a92.jpg&hash=70e7b25444634db6cd2e4798cd838af3)
![SlartiBartfast2_zpse09b692c.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2FSlartiBartfast2_zpse09b692c.jpg&hash=5d43fab3e5b0d12d2f766fb1b484fb62)
Warmoth Body:
Flat Top Soloist
Contoured heel
HxS pick-up routing
Warmoth Neck:
Warmoth Pro
Canary neck
Black Ebony board
1-11/16 nut width
Straight 12 radius
24 fret extension
SS6100 frets
No inlays/face dots
White side dots
Raw neck back
Hardware:
All black
EMG 81/SA
Gotoh tuners
Electrosocket
Single volume
![DeathbyUberschall1_zps15e525e5.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2FDeathbyUberschall1_zps15e525e5.jpg&hash=4f165eb572bd809544db40968dfa5f59)
![DeathbyUberschall2_zpsf0d16500.jpg](/proxy.php?image=http%3A%2F%2Fi1229.photobucket.com%2Falbums%2Fee479%2FUWFGOM%2FFEBRUARY%25202013%2FDeathbyUberschall2_zpsf0d16500.jpg&hash=0d1972273691443e44b54de57b01fa59)
