Faber Tom bridge
Flounderkeg
Ive been planning out this build for a jazzcaster, really want to have a tom/stopbar bridge. Warmoth offers one but I'm really interested in the ones made by Faber. Has anyone tried to install a Faber bridge on a warmoth body? I've gone to their website but there a different types of tom bridges so I'm just a little confused. Also am wondering if the fretboard radius needs to be a certain measurement to work with a tom bridge, or if it varies between tom bridges or if it doesn't matter at all. Thank ye
Warmoth's t.o.m. bridge route is drilled for metric/import t.o.m. bushings. So if you go with Faber you need to make sure to get the set with the "Epiphone/import conversion" bridge posts/studs.
I've heard that Faber parts are great quality and I don't doubt that but damn they're expensive. But if you're willing to shell out for it I don't see any reason not to do it!
Pretty much every t.o.m. bridge is built for a 12" radius, but if your willing to modify the bridge just a bit you can file the saddle notches a little deeper on the outer saddles (to fit a tighter radius) or file down the inner saddle notches (to get a fit a flatter radius). I have two Warmoth builds with t.o.m.s and 12-16" compound radius necks and went that route. With the 12-16" compound radius you want around 18" radius at the bridge.
Thanks I appreciate the info. My idea for the guitar is pretty simple, one pickup etc so im saving a bit of money, I can shell out a couple extra bucks for a better bridge id love to try it. Always used stock bridges so just curious to how much better they can be. And i was going to go for a 12 radius anyways so that's a relief.
To be honest i doubt this system is any better than tonepro, and aside from convenience in string changes, any 'advantage' of a locking TOM is fairly insignificant.
I’ve chased the TOM dragon with Faber, Pigtail, TonePros, and Gotoh.
TonePros are just Gotohs (flip one over, it says Gotoh on the bottom). The difference is the locking feature which I find to be wholly unnecessary… just leave one string on when restringing.
Actually “just Gotoh” sounds bad… Gotoh makes a fine TOM. That’s my go to recommendation.
Faber is great and when I upgraded my Epiphone with their metric set there was a marked, audible improvement in sustain and resonance. I also used a Faber on my SG with a Maestro trem specifically because the metric bridge w ABR-1 studs acts like a rocker, which makes the trem work better.
Pigtail - unless you’re replicating a 59 Burst, not worth. I also think you can’t get them anymore.
TLDR Gotoh unless you really need a locker then TonePros, Faber if you’ve got the coin and want something that looks right and will sound great.
I just noticed there's a Faber Germany and a Faber USA page... are they the same?
The Faber Germany prices didn't seem that expensive... Well, because I admittedly compared them to ABM, just to throw another manufacturer in there... 🤣
My only experience with ABM though, is from their compensated tele saddles, which are great. And since I know their factory is just a stonethrow from where I work, visiting that factory is on my list.
Local businesses ftw! I guess, if I'd build something with a TOM, I'd probably also spend some extra money... just out of sheer curiousity and admiration for good craftsmanship.
Thanks I appreciate the info. My idea for the guitar is pretty simple, one pickup etc so im saving a bit of money, I can shell out a couple extra bucks for a better bridge id love to try it. Always used stock bridges so just curious to how much better they can be. I was going to go for a 12 radius anyways so that's a relief.
Tom dragon lol. I think I may just try the Faber. Do you have any recommendations on the materials? I see they have titanium and brass saddles and also a hybrid model as well as a bell brass bridge. The guitar ideally is going to be solid mahogany with one humbucker, mahogany neck and ebony or rosewood fretboard. Also I hear ppl talk a lot ab aluminum stopbars? What's up with that, is there something that they add?
No experience with Faber. But have used Pigtail. Nice product but within 2 months, when top wrapped, it developed a groove that would break strings.
It did sound better. Went back to the factory tp. I now have pretty retired that guitar. It’s coming up on 50 years old. Use my R9 instead.
I have only ever ordered nickel plated brass saddles except for one bridge with nylon saddles on a project I never finished, I have no experience with titanium saddles on any guitar. As far as a bell brass bridge - also never tried that. Sorry!
Aluminum stoptails - I use them, they sound fine, however I think it’s more important to ensure you have steel studs/bushings that fit snugly. The Epiphone I referenced had a cheap pot metal setup from the factory and got a full Faber refresh, and the stock studs literally fell out during replacement.
Before:
After:
Before:
After:
I did a Faber upgrade to my Epi LP ultra. The stock studs were pulling out of the body on both sides.
Before:
After:
YO that guitar is sick!! How do the nickel played brass saddles sound?
