NutBehindTheGuitar
So Warmoth only makes the Superwide Neck (48MM Nut) on two models. The Modern Construction Strat replacement neck and the "Warmoth" Modern Tiltback. However only the Strat replacement neck is available with a Earvana nut. In fact it clearly states on the website.
"This option (Earvana) is not available on Modern Tiltback construction necks."
Okay clear enough, but why?
So I figured that it must be something to do with intererence between the possibly wider Earvana nut and the Truss Adjustment Nut which is right behind the nut on a Tiltback neck.
However this doesn't make any sense to me. The "Vortex" and "Warmoth" necks use the same simple rectangular nut that Les Paul type guitars use. Loads of Les Pauls have been converted to Earvana nuts without issue.
Here a cropped image of the "Vortex/Warmoth" neck nut area
In this image where the nut is absent, you can see the truss adjustment nut, and you can see a witness line where the nut sits. There is very little space between the witness line and the adjustment nut.
Now a compensated nut is wider, but all that extra width is on the fretboard side of the nut, not on the headstock side, so a compensated nut would not interfere with the truss rod adjustment.
Here's a picture of Les paul type guitar before and after being fitted with a Earvana nut.
Before
After
Both of these are screenshots from this You Tube Video
Here's a different shot of a different lesPaul that was retrofitted with an Earvana nut
This is a clearer picture and you can see there is no infringment on the headstock area.
The extra width in these nuts comes from their being a "Shelf Nut" design, or as I like to call them an "L" shaped nut.
The normal nut on these guitars is a simple rectangular shape or as I call them "Straight Wall" nuts.
So does Warmoth have some corporate edict against "L" shaped nuts?
Now I know a lot of you reading this, think that the whole compensated nut business is a load of malarky and so on. Please, this thread is not about the merits of compensated nuts, there are other threads for that. I have swallowed the Earvana koolaid and will not hear otherwise.
So I want a 3 +3 headstock on my next project guitar, and I want it with a 48mm nut and I want that nut to be a compensated nut. So far I'm out of luck.
Warmoth are the sole source of quality bolt on 48mm necks, and they refuse to fit a compensated nut on any of their 3+3 necks. What am I to do?
Before
After
