Earvana now has a compensating nut that drops in on a regular nut slot (on an angled headstock) with no modification to the fretboard.
This one is much cooler than the original Earvana IMO becuase it does not have the ugly screws on the top.
Its a 12 inch radius so if you have a 10-16 compound radius you would have to file the bottom of the nut a bit but that shouldn't be a big deal.
Here is the link from the Earvana site http://www.earvana.com/Gibson_dropin.htm
This is what I wonder about,
A) will scale length screw up how well it works?
I have seen this nut on 25.5 and 24.75 scale guitars so I am assuming its cool.
B) will down tuning to E Flat standard screw it up or negate the compensation effect?
The FAQ section on the Earvana site claims its works in e flat as well but I was wondering if anyone has had first had experience with alternate tunings using this nut.
FAQ LINK http://www.earvana.com/faq.htm
C) on the FAQ section of the Earvana site it says you shouldn't file the bottom of the nut, I don't really understand why.
It claims the the nut is flexible to some degree to adapt to a slightly different radius but I would rather file the bottom just a hair to make it a 10 inch radius and a perfect fit.
Has anyone out there used this on a 10-16 radius neck?
Did you file in the bottom curve a bit to make it a 10 inch radius or did you leave it at the stock 12inch radius on the bottom and file the slots to make it a 10 inch radius?
I have a neck on the way and will be trying this set up so I can let you know after that but I sure would like to hear some feed back before I try it.
