SkuttleFunk said:just be careful about the specifics of the inserts you're using ... and even greater detail to the tools and installation workflows used
if you're sloppy or make poor tool/workflow choices it is VERY EASY to seriously damage your neck
p.s. you're planning to utilize part number 400-3-CR and NOT one of the brass parts, right?
all the best,
R
SkuttleFunk said:brass has a tendency to crack as it's being installed into hardwoods like Maple. the last thing you want to be fixing during an installs is cracked inserts
stainless inserts, and also the hardened steel inserts, are wonderful. even so, it's highly recommended that you practice on some scrap Maple before attempting to install these on a real neck. you'll learn a lot on the first few you install - and this should help you get them installed perfectly perpendicular to the neck mounting face
you planning to utilize a drill press to do this install job?
all the best,
R
-CB- said:What ya wanna do, to set up the neck in the drill press....
Is put the heel of the neck flat on the drill press table, then place the vice upside down over it. Make sure they're both flat on the table, then clamp the neck (padded with carboard works well). When you turn it over, right way up, the heel will be facing the chuck, and the neck will be level.... This assumes that the table is set up correctly (90 degrees) and the vice is also parallel top and bottom... most are unless really really cheapo.
Plug the old hole first, that way you can use a forstener bit (edge cutting), and ease the hole into the wood. Set the stop on the drill press so you cant over drill too deeply. You want a medium slow speed for most forstener bits. They tend to get hot when you run them fast, and the small ones dont have much metal to dissipate the heat, so you can ruin the bit if you're not careful.
