dumb question wiring
TRG
i bought the wiring kit from waarmoth. whats the braided wire for? is that to use for grounds?
DiMitriR33
anywhere you can fit it, i use for the output jack on everything, on strats it can be tough to find other uses for it but on gibson style stuff i use the outer braided wire to connect the grounds and the inner wire as the hot. really helps with sheilding.
brownsound79
braided for ground..(white wire inside included..) :glasses9:
brownsound79
Yes Sir...all my terminal & solder joint are covered with heat-shrink tubing... :icon_thumright:  (its fun seeing those tube shrinks)
brownsound79
where do i live..?? uhhh very-very far away.... the other side of the earth...
but i can mods some wiring if u like...  :laughing7:
