thewrathchilde
Tried looking though as much on here as I could and a variety of other sites/searches but still couldn't find a good answer. The beauty of the internet is there is a lot of information out there, the bad part is sometimes it is hard to separate the good information from the bad. With no further ado here are my questions:
1. Does the type of wire you use matter?
I read on a couple of sites that Teflon Coated Silver wire is the best for guitars and using it or PTFE Insulated Silver wire over other wires will get a better, cleaner, stronger signal. They also indicated that these are the best wires for wiring your electronics (pickups, pots, etc) Is this correct?
2. Is Teflon Coated Silver Wire or PTFE Insulated Silver Wire the best two choices available or is there another type of wire that is better?
3. For any of you that use either of these wire choices, where do you buy it? I found several places online but couldn't find anything less than 100' rolls...... and I don't think I will ever need one hundred feet of wire for wiring guitars.....
thanks,
Steve
thanks,
Steve
