Warmoth told me their supplier for the metal headstock logos went out of business, and they haven't found a new supplier that can make a quality replacement. So I ordered a die-cut vinyl decal to put on the headstock of a neck I'm finishing with wipe-on poly. From what I can tell, I just peel it off, stick it on, then peel off the adhesive backing, similar to the Warmoth logos. This one appears to be a little thicker, which makes me think I shouldn't try to finish over it.
I've read that nitro will eat away at vinyl logos, and shouldn't be sprayed over them. I've found conflicting opinions on poly, with some saying it's fine and others saying there will be a reaction over time. My question is, would I be better off just sticking it on after the finish has cured? Or do I try to add additional coats of poly over the logo? This whole DIY finishing thing is new to me, I'm not sure how these types of decals are intended to be used. Thanks.
