TonyFlyingSquirrel
Master Member
Did some guitar surgery today. I figured, after 17 years, well over 500 gigs, several dozen worship services, counteless rehearsals, hundreds of hours of studio time, it was finally time to replace the giblets in my faithful TFS6 signature guitar. This time, I added a push/pull Volume pot to split the coils, and shrink wrapped every solder joint. Ain't nothing shaking loose on this baby! It's probably the cleanest wire job I've done yet, and it sounds clean & quiet, not hiss/hum or ground noise.
Parts replaced: 500k Volume Pot, LP Style Toggle Switch, Deep panel jack.
I still have the treble bleed cap/resister mod on the volume pot, although you can barely see it with it tucked under the positive wire from the toggle and the output wire to the jack.
