Deluxe 5 bridge
SkuttleFunk
only if you want your B and G strings floating in space  :sad:
it is possible to use a 17.5mm bridge, but that's as far as I'd comfortably go. an 18mm bridge puts the outer strings right on the edge of the fretboard rendering them unusable
all the best,
R
bgranger
Thanks for the response. I really like the Geckos and just ordered a 5 w/19mm bridge. That is the spacing that I prefer. I was planning ahead for o a possible 2nd build using the G5 body and angled neck. I was comparing them to my Pedulla Rapture-34" scale, 19mm, and my Lakland Skyline-35" scale, 19mm. I like both but I can tell the difference in that extra inch. I was thinking about something with a similar feel to the Pedulla.
