Seamas
I am +putting a decal on a headstock. It is an ink-jet waterslide decal (printed backwards) where I applied gold paint inside the black outline.
I am in the process of putting a nitro/Lacquer finish on the neck/headstock. I am currently waiting for it to cure before final wet sanding/polishing.
Now I know I should apply further lacquer over the decal, so my question is:
Should I do all the wet sanding/ polishing before applying the decal and then do 2-3 light coats over that--or should I apply the decal now before all the finish sanding?
