Tonar8353 said:
			Silverface Fenders are the best deal going. Some of the early ones still have blackface transformers in them and most of them can easily be "Blackfaced" by a good Tech.
To clarify what Tonar is talking about -
The Blackface and Silverface amps of the same or nearly the same wattage, have the same transformers.  Exactly the same.
Bandmasters were 45 or 50 watts - same iron.  Super Reverb 45 or 50 watts, same iron.  Twin Reverb 80 or 100 watts, same iron.  And so it goes though the entire product line from Champ to Twin (and Super Six and Quad Reverb and Dual Showman Reverb etc)
When Fender upgraded to the "ultra-lineaer" output transformers, giving the 45/50 watt heads a fully 60 or 75 watts, and the 80/100/105watt heads 135watts... things got very bad if you wanted a broken up gritty tone.  If you wanted clean - those amps did it.
The ultra-linear transformers contain a pair of "coil taps" which provide the voltage for the screen grids.  This voltage is not fixed, but remains a percentage of the total output transformer voltage as its in operation.  The result is cleaner, distortion free output section.  This was coupled with higher plate voltages, beefed up power supplies and huge power transformers to both up the wattage, and to mitigate any sag or "envelope" to the dynamic range.  These amps are characterized by squeaky clean tone, huge low ends, and rich full mids with sparkly highs.  If you play clean jazz, or steel guitar... you want one of these.  If you're a rocker, look for an older amp.  Its not worth trying to "convert" one of the so called "UL" amps back to black/silver specs.  You need to totally rebuild the power supply, change both the power and output transformers and add a choke, then modify the board layout.  Its real Frankenstein stuff... for all that, with parts and labor, you can sell the amp to someone who wants clean, and buy the right amp.   Also... if you have a small wattage amp, but want excellent reproduction of it on stage - one of the UL Fender amps is a great way to do that - with the appropriate step down to drive another amp from the speaker output of the smaller amp (very easy to build).
