macegtr
Hi guys,
Soloist under construction, here are the wooden parts which I got delivered to Finland in 8 weeks exactly. Quite awesome stuff and supplied as specified, thanks Warmoth :headbang:
Alder/flame maple laminated carved top body with a birdseye maple/black ebony fretboard. Body is prepared for recessed Schaller Floyd Rose, has 720-mod and contoured heel. Actual bridge will be GraphTech Ghost LB63-BK, to which I need to change shorter string saddle locking screws. Addition to GraphTech piezo-bridge for acoustic sounds I will be mixing passive and active pickups also, two EMG SA-pickups and Seymour Duncan Screamin' Demon (TB-12) for bridge position. I will be using EMG PA2 as a buffer (hidden into control cavity) to change the output of passive TB-12 to low impedance to work with active EMGs. No boosting needed, although that would be also possible.
I want to maintain the magical neck pickup position under second octave but still like to fit as many frets as possible -> this build will be a 23-fret guitar. Therefore before fitting the neck into the body I will need to cut the last fret off from the scalloped 24-fret fretboard :icon_thumright:
-macegtr
-macegtr
