Hello!
I am considering to do a Warmoth build.... I have parts selected already, and want to see if you have any comments about it or something.
Like incompatible parts, or maybe I can do the same for cheaper?
I have chose a neck and body from stock, having them build was too expensive for me...
Neck is a Warmoth Pro Construction Stratocaster® Guitar Replacement Neck. Maple with Indian Rosewood fingerboard, 22 frets, 61000SS frets(the bigger ones), prepared for a lsr roller nut. Satin finish. Nice thing is that it has a reversed headstock, not so nice is that it as inlays(I dont really like inlays...) $292
Body is an Alder Soloist, no other wood top. It has contoured heel and recessed Wilkinson tremolo cavity(they will insert the studs from the brigde in the order).
Routed for HSH, and all of the possible control drilled and battery box. Unfinished. $197
In the Warmoth cart I also have:
On other sites carts I have...
[/list]
My plan is to put a pair of Lace sensor Duallys in the bridge and neck positions, leaving the middle empyt for now. The mini switches are meant to select between each dually possible configuration; and the blade is a 'global' selector for whatever is on either dually. I will have to drill two holes for this...
I will be using Tone Monster SBK-3AB (http://www.ebay.com/itm/111234215444, which has the volume and tone controls. I will be removing the blend pot from the circuit...
This will need an stereo jack, and two concentric pots besides a normal one for the volume.
Dunlop straploks and "Schaller style concentric lock tuners" from ebay...
I will be doing this with the body (http://youtu.be/9pGrhc1jQBY), just with Evangelion manga
If my calculations are right, all of this would be around $784USD; without the materials for the finish.
Is there anything Im forgetting? Anything I could do for cheaper?
What do you think of the build itself?
I play Hard Rock and Metal, more similar to the 80s one that the modern one.
Thank you very much!!
- Gotoh Wilkinson tremolo VS100
- Electrosocket with Switchcraft Jack
- Neck plate and correct screws
- Roller T String Retainer for Guitar, Pair
- Battery box
- Fender LSR roller nut
- Wiring kit
- 3 blade way switch
- 2 on/on/on mini switches
- Pickups
- Tone moster Pream
- Dunlop Straplocks
- Necessary knobs and switches tips
- Schaller Style concentric locking tuners
[/list]
