Kain VKail said:
so i bought this stuff and i think it was a good idea...i hope it was. but how should i apply it. and when applying it what should i be wearing.
Can i do it outside instead of in a garage because all i have is out side to do any work.
And when im done how should i let it sit to dry. can i leave it in my basement? i cant do the work there with the opened container because its not very well vented.
Since you already have the stuff, we'll skip the discussions about its efficacy.
Applying it is as easy as painting anything you'd paint with a brush. Just brush it on. It's never going to be seen, and pickup/control cavities don't have good surfaces anyway, so don't worry about brush stroke marks or anything like that. Use a narrow brush, maybe 1/2" to 3/4" wide.
The stuff I'm familiar with is water based, so clean-up isn't a problem. Kitchen sink works fine, if you have running water <grin>
Don't worry about ventilation - there are no combustibles or VOCs involved. Treat it like latex interior house paint.
It's a little thinner than house paint, so don't try to glop it on too thick - it'll run and puddle. Better to do several coats instead.
Let the body sit flat to dry.
As for what to wear, I'd get some nice Calvin Klein designer jeans, a ruffled white shirt with black piping like you'd wear with a wedding tux, and some high-top Raeboks for your feet. Get a pair that black won't show up on so easily, such as these...
Or, you could just wear anything that you don't mind getting paint on. Unless you're some kind of clumsy animal with little motor control and no opposable thumbs, I can't imagine you'll have much of a problem with that anyway <grin>
Actually, since you can apply it indoors without any problem, you don't necessarily have to wear anything at all. Paint it, clean up your brush (or just throw it away), and go take a shower. You'll be fine.
