Heft
I want to put an Underdrive unit (http://www.guitarheads.net/products/electronics/underdrive.html) in my telecaster and I'd like it to only effect one pickup. I also wan't to be able to toggle it on and off.
I know I can do this if I have a push/pull tone pot distinctly for that pickup, I would like more options.
I would prefer not to have two tone pots and a master volume. There doesn't look like there is enough real estate under the control plate for three pots and a traditional 3-way switch.
I've brainstormed a bit, and these are the best ideas I have right now,
-Dual concentric pots for tone and volume, and a switch for the tone I want the Underdrive on,
-Instead of grounding the Underdrive to the pot, -put it in circuit between the pickup and a DPDT toggle switch (switch connected to tone),
-Use a Les Paul style 3-way switch instead of a normal 3-way. Then use two -tones and one master volume (although I don't know if there is room for this in a tele control plate).
Would any of these of these work? Is there a right way of doing this?
Thanks,
Heft
Thanks,
Heft
