NeilStryker
Hey guys... my current build is at the luthier/repair shop getting final assembly - it is a H-S-H strat shape body. Both Humbuckers are to be split with push-pull pots. It is all wired up now, but there were a few problems, only one of which I will go into.
Unbeknownst to me, my repair guy flipped the orientation of the coils on the neck humbucker from the way I had it set up in the pickup ring when I dropped it off. For visual reasons, the neck humbucker is backwards of how it would "normally"be, i guess... He put the black coil towards the neck, which is wrong.. I asked him to flip it back, which i now am realizing will make the coil which is on with the coil split activated would be the inside coil which would not be the right way? right?
So my question is.... which coil should activate when the coil split is activated?? I am thinking the farthest coil towards the neck right? So he will need to re-wire the pickup, because just flipping the pickup in the ring will not solve the problem? right?
here;s a pic.... this is how the colors of the coils should be oriented (the repair guy flipped the neck one around)...
